90hp johnson fuel mixture
alanR1
i just got a 1982 90hp johnson and a couple of you answered my question on a soaking to unseaze and now I wanted to ask if anyone has some advice on what type of fuel mixture I should run through it after I soak it and hopefully break it loose. What would be good to get the juices flowing and everything spinning like a well oiled machine.<br />Thanks again guys.
Re: 90hp johnson fuel mixture
Break in for rebuilt engines calls for 24:1,double oil. Wouldn't hurt anything if you wanted to. :)
D
DJ
Guest
alan,<br /><br />I agree with 24:1 for maybe six gallons or so. That mixture tends to load them up pretty quickly.<br /><br />If you do run it like that for a while, I would do a decarb. right after that. 50:1 is "normal".
JB
Hi, Alan.<br /><br />After the 6 gal at 24:1, use 50:1.
alanR1
what is decarbing?? Removing the carburator and cleaning out the jets?? How long should I fun it at that mixture?? I don't want to foul the plugs or anything. And should I put it in the water to do that or should it be ok to put on the earmuffs off the house water.
alanR1
last but not least what type of oil should I use for maximum performance w/out costing me an arm and a leg.
