90hp Johnson rebuild
revismi
I have a 98 model Jonhson 90hp without VRO that has #1 and #3 pistons rings :confused: broke and caused damage to the pistons and cylinder walls. I have an estimate for 1200.00 to rebuild power head along with carbs and waterpump. Is that about right?
dkondelik
Re: 90hp Johnson rebuild
Sorry to say "Yup"! $1200 is not bad for a Good, Complete power head re-build with a warrenty.<br /><br />Hope it works out for you.
Dhadley
The main thing is to rectify what caused the problem. Starboard side broken rings are usually a result of coking. Set up is key. Look for 5800 rpm with an average load. If youre in the low 5000 range now you may want to look at set up to get the rpm's up.<br /><br />Good luck!
