1987 3 cyl.#ob196221..have spent last 2 days sifting thru post,this is a great resourse,maybe you can help me a bit farther.motor ran fine..suddenly started surging at top speed,thought maybe something got sucked thru carbs as it ran fine again,then again with the surge and die also, hard to start back up. compresson is at 120 for all 3 -spark alternates on bottom 2 cyl.sometimes there sometimes not. rectifier test shows no continuity anywhere. is the rectifier the source of my problem?is that good comp.for that motor?if my ignition switch got stuck[weak return spring]could this cause damage?thank you very much
