90hp Merc o/b starting problem
2001 Boston whaler, 90hp merc. will not Start. when turning the ignition key, it will not turn over, motor just clicks. Battery is good, all gauges work when key is engaged. the motor will turn over intermittenly, but will not start. This started this fall while out fishing however, after 1 or 2 trys the turn of the key would turn the engine over and start. The boat has sat for a few weeks now, and the problem has got worse, whereas, the boat will not start, and 1 out of every 100 turns of the key will even turn it over (but getting worse). Does this sound like the starter? Trying to get it out of the water ASAP, b/c more snow is on the way.
Barnacle_Bill
Re: 90hp Merc o/b starting problem
Sound like you need a new solenoid. You can verify this by jumping the two biggest wires at the solenoid. Be careful as you will have sparks.
Thank you for your speedy responce Bill. If I hear a clicking while turning the ignition key would that tell whether the solenoid was good /bad? <br /><br />I tried it again and now I cant get it to turn over at all, it just clicks when I turn the key.<br /><br />When I was able get it to turn over it would not start up. Would a bad Solenoid or starter not allow it to start, even though I had it turning over? Thank you in advance for your patience.
LubeDude
A solenoid can still be bad even though it wont turn the engine over and makes clicking sounds. These engines need all the battery power they can get also.
budman8330
I would start simple. Check EVERY connection from the battery to the starter. Clean them all very well. I had an evinrude that did that, i ran myself in circles checking and testing EVERYTHING, then after a few days of that, i decided to clean all the terminals, it cranked everytime after that. <br /><br />good luck
Thanks BUDMAN,<br />Will do. I hope its a bad connection, another problem thats factored in is that the temp o'side is in the 30's, with a cold battery perhaps not supplying enough juice could be the reason it will not start after I got it turning over? dunno. figuring whats wrong is my biggist problem.<br /><br />wet & cold
budman8330
it depends too, batteries that are openly exposed have a tendancy to freeze, and it messes with the plates. <br /><br />but i dont think thats the problem here. <br /><br />try jumping the solenoid, at least then you can rule that out :) <br /><br />be careful though, thats a newer and nice boat.
as of today everything points to the starter. got one on order.... arrives tue. We've got a nor'easter headin down on us tonight w/ another storm next week. thanks for your help budman.<br /><br />the only question that remains is, why do these thing happen always happen when is freaking freezin out?
budman8330
boats dont like the cold either i guess. <br /><br />i sure know my camaro runs like a champ in this weather though :D <br /><br />thats about the only positive i can think of that comes out of the cold :)
Texasmark
The clicking is the solenoid closing and opening. Every click is it slamming shut. By it clicking it means it closed and reopened (when it was supposed to stay closed and allow voltage to go to the starter to spin it).<br /><br />The amperage required to start that outboard is about 100 amperes as I recall. That's a lot of current. When you turn the key, you close the switch (solenoid) and attempt to force 100 amperes through your high current wiring from the battery thru solenoid high current contacts, to the starter, and back to the battery through the aluminum housing (block) of your engine.<br /><br />During that process, you need to maintain enough battery voltage to keep your solenoid energized (by way of the start switch). If the batteries are weak, or your starter is shorted, or overloaded (like with a frozen engine), as soon as you put a load on the system the voltage drops from 12+ volts to something less than (probably about 8 volts), which is not enough to keep the sole energized.....so it drops out. ]<br /><br />When it drops out the voltage pops back up to 12+ volts (cause you removed the load on the battery), the sole coil sees it, re-energizes (cause the voltage is high enough to do it now) and the cycle repeats.<br /><br />In short: Bad batteries (have auto zone load test them for you...min 100 amps), shorted starter, or stuck engine.<br /><br />But, if all that checks out, the ignition-switch is defective (burning up inside) and is unable to get 12+ volts to the solenoid coil (excessive voltage is dropped across the switch cause it's defective) usually happens with old switches exposed to moist environments.<br /><br />HTH,<br /><br />Mark
