90hp. nissan
pvanv
Re: 90hp. nissan
What model? Any warning lights or buzzer? Was the CD bad? If it's a 90A, how is the link and sync, and how clean are the carbs? Is that 3000 limit only when running on the boat? If so, what prop are you running? When did the issue start?
Sea Rider
Re: 90hp. nissan
If engine runs even throughout the entire throttle range, you could have a spun prop ?
Happy Boating
TOHATSU GURU
Re: 90hp. nissan
my motor wont let me get over 3,000 rpm's changed cd unit what else causes thie help thanks
Almost everything effects the RPM, so, you have to troubleshoot the engines three systems and determine, by process of elimination, what the problem is.
greg daigle
Re: 90hp. nissan
its a 90a and prop good and correct size no buzzer or horns carbs clean and sync it correct.
pvanv
Re: 90hp. nissan
Start with the Factory service manual as a guide, and troubleshoot the fuel, electrical, and mechanical systems... in that order. No shortcuts on these.
