90hp sportsjet power loss
damage inc
hay iv got a 90hp sportsjet oe067119 in an 94 bayliner jazz. last year i was running without intake grate/screen and BAMM! staled moter. after gitting it started boat inpeller/prop was damage so i hobbeled it back in.this year got new impeller had shaft reworked to fit splined rather than threded,So get in the water and cant get up to speed.Big power loss takes time but do get up to 32,(45mph reg) bogs in turns just missing power,after this i took it in to a shop they said it had no compression in #1,but mec also implyed he had just did a compresion and nothing as to keep down 75.00 hour rate,now i today started too pull the powerhead by book ,and found both exhaust boot clamp loose like u could spin them freely/Would this cause my prob& give low compresion?
SB
Re: 90hp sportsjet power loss
A loose exhaust boot should have no affect on compression. I would advise checking the compression yourself. It is very easy, if you don't have a compression gauge they only cost about $20. Be sure to check with the throttle in WOT. The shop manual gives good direction on diagnosing compression problems.<br /><br />Lack of speed could also be due to a leaking ride plate. Since you have had work done in this area I would suspect that if the compression isn't the problem.<br /><br />Good luck.
