'91 200 HP Mariner - Oil Injector Question
I have the above mentioned motor and would like to add an oil injector. I have seen the port near the carbs and was wondering what parts I need to start locating and any advice you guys may have
gss036
Re: '91 200 HP Mariner - Oil Injector Question
I would think you would need to find out why the orginal was taken off before you think about reinstalling one. OR! are you wanting to add an electric injection?
Usually the orginals are removed because of a failure of the pump rod/plastic gear on crank, this requires a tear down of the engine to repair so most just eliminate the pump and pre-mix.
