tampaaquasport81
- Joined
- Dec 22, 2008
- 31
iv got a 91 200 jonson looper that will not stay running when in the water but will on the hose. the motor idles fine and then ignites and tries to cut itself out. when i try to give it throttle in gear most of the time it will die but for the times it doesn't it will clear itself out and want to get on a plane seems to run fine. i launched on a river so i can't get on a plane to see. so far i have replaced the power pack, timer base, wires, swapped out vro pump with used one, the old timer base had a pit about 2" long on the insid when i replaced it. i figured by replacing the timer base it could have affected the timing so i adjusted that bt didnt do anything. fuel is changed to premix 50/1 and i put new gas and water seperator in about 3 months ago. i checked to see if maybe it wasn't getting fuel by priming while throttling and it didn't help..
