91 40hp johnson trim switch
rjrobin2002
My trim switch will only raise the motor. I have tried the one on the motor and the one on the controls and the both just raise. I tested the switch with a volt meter and the switch is transfering 12 volts to each post, but only the trim raise is working. I can override the switch and raise/lower the motor with a battery pack and switching the 2 wires that go to the trim motor for up and down. Any sugestions why both switches are doing the same thing?
ezeke
Re: 91 40hp johnson trim switch
Try swapping the relays and see if the problem reverses; if so, replace the relays.
tashasdaddy
black box 3" x 6" 1 " thick. exactly where on that motor, i can not tell you. will have big blue and green wire coming out of it.
