I have a '91 Johnson 48 Special that idles fine but sometimes when you are planing off or shortly after you get planed off motor starts to 'buck' with rpms slowing and then increasing in cycles. If you don't pull back on the throttle, it will eventually die. If you do pull back, it will idle fine. Even if you pull back to 3/4 throttle, it will run fine of a few seconds then start to buck.<br /><br />I've traced fuel system up to the carbs. Fuel supply is OK. Thinking of rebuilding carbs if I can find kits. Any other suggestions?<br /><br />Billy
