Can someone help me? When I shift into forward then try to shift back to nuetral my shifter gets stuck.It's like there is something binding right before it gets to nuetral.To get it back to nuetral I have to shut the motor off. If I'm in forward but just barely on the throttle and pull it back to nuetral it's real hard but after a few seconds sometimes it will release to nuetral.I disconnected outdrive cable from carb and it moves but not to easy.I've pulled the other cables off and they seem to be move freely.I guess if you think it's the outdrive cable can tell me how hard it is to replace?I've already replaced the shifter. Thanks
