what should the compression be on my 91 johnson 50hp VRO
I IRONRANGER Cadet Joined Jul 1, 2009 Messages 7 Jul 1, 2009 #1 what should the compression be on my 91 johnson 50hp VRO
W wilde1j Vice Admiral Joined Apr 15, 2002 Messages 5,964 Jul 1, 2009 #2 Re: 91 50hp johnson / compression No specific number, but over 100 psig and cylinders within 10% of each other is good.
I IRONRANGER Cadet Joined Jul 1, 2009 Messages 7 Jul 1, 2009 #3 Re: 91 50hp johnson / compression If im wasting your time Jim why bother to reply?
T tx1961whaler Vice Admiral Joined May 31, 2008 Messages 5,197 Jul 1, 2009 #4 Re: 91 50hp johnson / compression He's not insulting you. That's a signature that appears on the bottom of all his posts.
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Jul 2, 2009 #5 Re: 91 50hp johnson / compression IRONRANGER, your reply was uncalled for. compression #s are not published by any outboard manufacturer. the reason being, guages are all different. you got the correct info from wilde1j
W wilde1j Vice Admiral Joined Apr 15, 2002 Messages 5,964 Jul 2, 2009 #6 Re: 91 50hp johnson / compression The stuff below the line is just part of my signature ... lighten up.
