I am still working on removing my stuck trim tilt unit. I drilled out the release screw and tried to ez it out but it would not come out. I drilled all the way through it and let it release the fluid little by little. Lifting the motor up and down released the fluid a little at a time. Tried drilling a hole in the pump under the tilt motor to help release the fluid. Motor up and down, little by little fluid came out. I have the engine almost high enough to take off the retainer clips on the top pin and remove the unit completely. NOT A EASY JOB. will have toreplace the tilt motor and the pump. Any suggestions on a good place to purchase ?
