Today I took the boat out and could only get 3800 RPM@wot. However when I started to prime the engine the RPM starting coming up to normal. I was priming from the key. Last year the outboard had the VRO disconnected and the oil was being mixed with the gas. Engine runs fine with VRO disconnected. Over the winter I went through the motor and put a brand new VRO pump. fuel line and went to the factory OEM Evinrude plastic gas tanks. Compression is good and within 5lbs of each cylinder. Yesterday I had the water hooked up to the intakes and its shoot out a nice stream and idles great. I put throttle on the engine and climbs great. By hooking the VRO back up is there anything I need to check to make sure the timing is correct?
