91 70hp Johnson VRO question
ggrimm01
Previous owner disconnected the VRO and mixing gas/oil. I know there are 2 camps on this. I have put everything back together and hooked up the VRO. I am running the rest of the gas/oil mix into the motor until I know the VRO is getting oil into the motor. One sign is the motor is smoking alot more. Once I know the VRO is working I will start using straight gas. My question is how do you know the VRO is working? I am monitoring the oil tank. I also have a new VRO tank setup and filter because the old VRO tank hose is very hard and not pliable like the new one. I am also putting in a tank guage to monitor the oil.
sutor623
Ughhhhhhhh wont let me post due to forum rules. I will fix it.
Note: If you find that the VRO pump is bad after testing with this method, replace the pump and do not attempt to kit the pump. We have found that the kits fail more than not, and the cost of such a failure is certainly not worth trying to save a few bucks.
Ok, let's test the pump....
Using diagragm for reference, install and carefully secure a 10" length of 1/4" clear vinyl hose to oil inlet on pump. A few inches from the loose end, measure carefully, and mark hose every 1/2" for 3 inches.
Fill the hose with outboard oil and run the engine to eliminate air from the base of the hose. Shut off engine, and add or eliminate oil until level is even with the highest mark.
Start the engine, and monitor the pump cycles by using a fuel pressure gauge or by putting light finger pressure on the outlet hose.
  • At 800 RPM, the oil level in the hose should drop 1" in approx. 5 pulses.
  • At full throttle, the oil level should drop 1" in approx. 3 pulses.
If results vary from above, the pump could very well be bad, but check the pulse limiter fitting before replacing the pump. Disconnect pulse fitting hose and crank motor. Is there a good strong pulse of air through fitting? If so, fitting is ok. If not, first check that compression on bottom cylinder (which operates pulse valve) is up to snuff. If compression is low, then the bottom cylinder needs attention to correct. If compression is ok, replace fitting and repeat previous test to assure oil throughput is ok. If results still vary, replace pump.
