91' Bayliner Capri 2070 w/ Force LD 120hp - Fuel Filter?
Open Waters
Hello all.
Needing some help in selecting the appropriate in-line fuel filter? Thanks in advance.
Open Waters
pnwboat
Re: 91' Bayliner Capri 2070 w/ Force LD 120hp - Fuel Filter?
There are many choices here at IBoats if you wish to add a filter between the fuel pump and carburetors. Here's a few.
This one is a disposable all plastic for 5/16 fuel lines.
http://www.iboats.com/Mallory-Filter-Fuel-5-16-Inline-9-37959/dm/*******.760002294--**********.686281457--view_id.365276
This one is glass and is reusable and has fittings for 1/4, 5/16 and 3/8 fuel lines.
http://www.iboats.com/Seasense-In-Line-Fuel-Filter/dm/*******.760002294--**********.686281457--view_id.56073
jason32038
I purchased one just like the glass one but mine was all metal..anyway the cheap plastic screw in connections are garbage and wouldnt even thread in right. I originally purchased it for my truck and couldnt even use it because the cheap plastic threads stripped out. On the other hand you can get brass fuel fittings for it and it should work great.
