"91" Evinrude 70 VRO...Dead short?
babes@sledbabes.com
Our Evinrude is not starting, turn the key and the starter motor engages but can barely turn the motor over. The motor does turn freely when moved by hand on the top a bit of smoke will roll up from under and behind the motor (with the hood off) smells like rubber or plastic. Also the tilt/trim will not work now. Could anyone give a hint as to where a dead short may be on this machine back/behind the motor.<br /><br />Thanks,<br /><br />Dona from sledbabes.com
norman158
Re: "91" Evinrude 70 VRO...Dead short?
check your engine ground and the hot terminal on the solnoid
