I have a 91 Force 50hp, overheat alarm went off and noticed no water out of the pee hole. Decided it must have been time to change the impeller, but after pulling off the lower unit and water pump cover the impeller was almost perfect. I checked the lower unit vents and found no obstructions, checked up the water tube headed up as far as I could and found nothing... So now I'm lost, any suggestions?
