Old Coasty
- Joined
- Jun 6, 2005
- 17
Model J150GLEIS. On 91 Lund Pro V 18 ft. 14 1/2 x 21 aluminum prop. I had motor rebuilt in August. (See post from 7-25-05 "91 Johnson idles rough and dies when put in gear"). It's now broken in enough to go WOT. It tops out at 45-4600 RPM's @ 45MPH on boat gauges. It used to do 55K RPM @55 MPH when running good before motor problem. I told mechanic (certified Johnson shop that did rebuild) and he said to bring it back. He put in his tank with load and said it ran up to 5800. He said everything looked good but he did change the timing from 18 to 20 deg. We agreed to try a 14 1/2 x 19 prop to see what would happen. With 19" prop it ran up to 5500 very quickly. I had to back off throttle to keep from over rev. Next day I put the 21" back on and it ran like it used too 55K RPM @ 55 MPH. I thought all was fixed. Fished for a while. On way back to dock tried WOT and the best it would do was 45K RPM. Where do I start? FYI-new fuel, champion QL78YC plugs. I'm still running double oil in fuel for break in.
