huggyb1972
- Joined
- Apr 1, 2013
- 253
Hi All I am having some trouble with my fuel system on my Boat and would like a little advice. The boat is a 1990 Spectrum 1950 Sportsman. Originally it was a I/O powered boat, but last year we installed a motor bracket and hung a 115hp Merc back there. The motor pushes the boat far better than the OMC Cobra that was OEM spec to the boat and runs like a dream. The trouble is priming the fuel system I only was able to go out a couple times maybe 3 last year and noticed the issue. This year I grabbed a new primer bulb, But forgot it on out 1st cruise out which other than the 1st startup on the trailer it ran flawlessly. Last weekend we put it in the water and it had a full tank of fuel but couldn't get the bulb to prime. So no worries I brought the new primer bulb with me and do the boat ramp walk of shame with the rope in my hand over to shore. Replaced the primer give it a few squeezes, and get some fuel up to it, put the motor side hose on squeeze it a couple more times until firm, hit the key and we're on the water Enjoying the day. The next start after the motor had been off for about a hour I had to loosen the Motor side hose again to to prime it with fuel. I'm loosing prime somehow but I'm not leaking fuel or anything obvious.
How should my fuel system for the outboard differ from the I/O that was previously there? The tank is a 20ish gallon aluminum below deck center mounted tank. The vent allows fuel to spit out upon a full tank so I don't believe it''s obstructed. The fuel hose to the motor is less than 8ft long and theres probably at or a little less than 3' difference in elevation from the tank to the motor fuel connection. Eventually I'm going to Hang a new 4 stroke outboard back there like maybe a Suzuki 140 or a Yamaha not sure yet I just want no trouble. thats all.
