91 OMC 4.3 ESA Problems
Tstein81
I have a 91 OMC cobra 4.3. When shifting into gear the the system grinds until it goes into gear. The RPM's is set to 800 according to the manual and the ESA doesn't seem to be dropping the RPMS when trying to shift. I pulled the shift interrupter lever and the engine doesn't respond most of the time. When it does react, the engine just dies and have to restart it to try again. Any thoughts?
Renken2000Classic
RPM is too high. Are you actually working the microswitch to test it? Is the motor running well otherwise? It shouldn't die, especially from 800RPM unless something else is wrong.
Lou C is the expert. Search with his name and you'll find all kinds of stuff.
Tstein81
I am working the microswitch and i also tried moving the "W". Same results. The engine purrs and idles perfectly.
