i have a 91 omc outdrive,when i put it the water last wk.water started to come in from around the bottom of the transome,i took it out of the water and then hooked up my water to the out drive and you can see water leaking in ,but when you put it in the water it really comes in,where should i start looking,,a friend said it could be some exhust pipe to the transome that could be bad,,,,also is there supposed to be gear oil in the u joint boot?please help so i can get it back in the water,,,i just recently rebuilt the engine,,,
