Hi all
I have a E30RLEN.......1992 30 HP, rope start evinrude.
I purchased it after it had been sitting for possibly a year or more. The engine was on full tilt and had some water under the hood. It started and ran well on the muffs so i took it up the river. It refused to go much past and idle on that first run and dropped straight to one cylinder on anything more than mild throttle.
Once i got it home i checked that each cylinder jumped a 3/8 gap. They both did but it did look like a fine blue spark to me, i expected a bit of a thick strong spark comparing this to my 9.9/15's that i have played with over the years. This could be normal or i could have a weak spark, however it is jumping a 3/8th gap. I also pulled the plugs with a rubber glove and pliers, one cylinder gave me mild shocks (nothing like an old seagull that nearly belted my arm off once) and the other nothing, both time the motor ran on one cylinder on the muffs. I also cleaned up the earths and connections.
On the second outing it dropped out a few times but came good.
Today i headed out with a timing light and a battery out of my quad on after a few fishing stops i gave it full throttle for a period of time. After a few minutes is started cutting in, out, in, out, in out repeatedly and quickly but my timing light refused to work on either cylinder, it might be dead or it might need more than 12v to operate, or perhaps a stronger spark. I eventually backed off to quater throttle, stopped and had a fish then she was fine all the way home.
I am thinking power pack or coils, any ideas or suggestions???
