I have an issue where the motor doesn't want to idle when hot. If I mess with the choke (you will see in the video) it helps, so I'm guessing a lean condition of some type. I can fix the problem by cranking the idle up however when cold the motor idles at 1600 - 1800 rpm. Sometimes it will also come up high even while hot.
In the video you can see it idling poorly.
I sprayed carb cleaner all around the base looking for a vacuum leak and couldn't find anything.
Also, what is the hose that comes off the front of the carb and goes somewhere below the motor? I didn't have time to trace it tonight.
