92 60hp Johnson 3 cylinder - Carb Sync w/o the tool
hypeshipe
Any tips on syncing the carbs without the manual recommended cylinder tool? I'm bogging pretty hard at low speeds and it won't idle too long with conking out. I would like to run through the carbs tonight so I can get it out tomorrow but I don't have the piston tool to sync. Help me fish tomorrow!
boobie
Re: 92 60hp Johnson 3 cylinder - Carb Sync w/o the tool
If you haven't changed the timing pointer position on the top of the block, you shouldn't need the tool.
