92 Cobra -Shifting Issues
Limited-Time
First off I searched for "Cobra out drive shifting problems" and read through all the threads. I did not find anything to indicate weather the shifting problems were only evident while the boat/drive was in the water (under load). Also the shifting issues only seem to be evident in the older model Cobras. We have a 92 OMC 3.0 Liter HO coupled to a Cobra out drive, that functions fine on the trailer. However in the water it becomes difficult to "find" neutral. If this is the same issue as discussed in the fore mentioned threads just let me know and I will review the procedures supplied there and correct the problem. If not HELP. Thanks
a.d.mobile
Re: 92 Cobra -Shifting Issues
look for shifter interupter issues or ESA module make sure you have a good set of points installed and gap set properly. bob
Limited-Time
a.d.mobile,<br />Thanks for the response....I went back and re-read the fore mentioned threads and picked up a few things I missed. It all seems to be tied to the ESA module as you stated. Have to order a manual before I can procede, thanks again.
