reelfishin
- Joined
- Mar 19, 2007
- 3,050
I just picked up a really clean, freshwater run Dt 85 but it developed a miss after about 3 hours of running. The motor runs cool, has 137 psi on all three cylinders but drops a cylinder at cruise
It stalls at idle and progresses into a backfire/stall after a few minutes of the problem surfacing. When got the boat, the tank was full of old gas, I changed the fuel, flushed the tank, cleaned the carbs, and changed the plugs. It made no difference. It seems to run better at higher RPM than lower RPMs.
It at first felt like a carb issue, sort of bog with some loading up at lower speed, but it now missing always, the middle plug looks new and dry, the upper and lower come out wet and black. The motor has only about 4 or 5 hours of light use on it since I got it. Compression hasn't changed.
At this point I really am not sure if it's a carb issue or a coil or something dropping out. After it stalls it fires right back up, but it had big issues accelerating again, once on plane the missing cylinder cuts in and out at will, dropping to an idle will almost always mean a stall out.
I ordered a manual but have little to no experience with these motors.
Is there any thing that their known for? I thought about maybe a bad headgasket, but the compression it good and I don't see any signs of water in that cylinder. All coils put out a good blue spark on each plug.
The bogging sounds like carbs but the sudden stall and backfire has me a bit puzzled. The odd part is that this motor will start with no choke in less than one crank of the engine, always.
I have no real history on the motor but it looks pretty well cared for overall.
Any ideas?
Any ideas?
