'92 Evinrude 120 idle
baggywinkles
What rpm should this engine be idling at? Also, where is the idle adjustment/what's it look like?
Dhadley
Re: '92 Evinrude 120 idle
Hey neighbor! Set it at about 650 in gear in the water. Out of the water itll be somewhat higher (no backpressure). Set the throttle linkage as per your service manual and the idle is set with the timing. On the starboard side right above the carbs theres a plastic handle looking deal with a lock wheel.
baggywinkles
Hey! You're a survivor too? House sustained 25K but it's back together now.<br /><br />Thanks for the tip. I'm not much on mechanics.<br />jim<br /><br />
Originally posted by Dhadley:<br /> Hey neighbor! Set it at about 650 in gear in the water. Out of the water itll be somewhat higher (no backpressure). Set the throttle linkage as per your service manual and the idle is set with the timing. On the starboard side right above the carbs theres a plastic handle looking deal with a lock wheel.
Dhadley
We were a bit luckier. 22K but we're still here. Hope your motor gets going OK.
