I just got an older boat from a co-worker, '70 Newman, and this motor( 92Evinrude 48hp, Model# E48ESLEN )came on the boat, and he said that they both were going to need some work. So I first started by charging the battery. That worked. Then I got good gas w/ the correct oil mixture. I took a while but was successful in getting the motor running. **And yes and made sure that I had a water hose running and hooked up to the motor, so I wouldn't burn it up.** I got it to crank up. It idled low and would cut off, but I adjusted it and think I have that fixed. I have been able to run the motor with no problems that I can see. I can throttle/rev it up fine. When it comes down it acts a little shakey. I have also been able to turn down the throttle(cold start) and engage the propeller with little problems. ***here in lies the problem*** I took it out on a lake Tues, as soon as I put the boat in the water it took 10min to get to crank up and idle, and that was just so I could take off the trailer. I then parked it to move my car. When I came back it took another ten minutes to get it started again. I was able to get it goind and was moving along pretty good. However, as soon as I tried to accellerate....nothing...it just stayed at the same speed. It did for about 10-15sec go to full throttle, but came back down. So I tried to push the key/choke to boost some fuel to the engine and it acted like it wanted to increase speed and power, but it did not.
ANY HELP/IDEAS would be greatly appreciated.
