I have a 92 xp 150 hp evinrude that had the carbs rebuilt. I went to use the boat over the weekend and the bulb would not pump up solid. Gas would however pump straight out of the second carb. I was told to take the carb off and take off the float area and blow through the carb from the opposite direction to remove the junk that may have got. I did so but it seemed the float was upside down,is this possible? One note after the carbs were rebuilt the marine dealer ran the motor before I brought it back home and it seemed fine at that time. Is that possible if the float was upside down?
