Greetings!
I finally got my motor back together (2 new pistons, new rings all around, head gasket, new impeller). I ran it around all day Saturday towing skiers, wake boards, etc... and had no problems whatsoever. Sunday I cruised the lake at "slow no wake" speed and it overheated. I cooled it down, cruised again and it overheated. The alarm never went off, but it was HOT and a lot of steam was coming out of the tell tale.
I think I have the impeller in right (vanes bent backwards with rotation) and there is water coming out the tell tales. I tested the thermostat in hot water and it works great. The carbs haven't been adjusted since I bought it in 93 and I'm sure I used the right oil/fuel misture. I'm at a loss.
Here are my questions:
Any idea why it would overheat at slow speeds and not at WOT?
Would running it without a thermostat harm the motor?
Is there any way to check if the water jackets are clogged?
What else might cause this problem?
I searched this forum but found nothing similar to what I have, and I'd really like to figure this out by the 4th. Any help would be greatly appreciated!
Thanks in advance!
Kevin K.
Thanks in advance!
Kevin K.
