92 Johnson 120 Fuel Pump
I have seen people talk about a VRO pump conversion to run oil in the fuel in the tank. I called my local dealer and they did not know what it was. Does anyone have a Johnson part number. My motor is a Johnson 120tlamd
Thanks
rickdb1boat
Re: 92 Johnson 120 Fuel Pump
Part number 438402 is the fuel only replacement pump. Dealer should have this and it should come with a new pulse limiter(Blue) or click the link below: It is a direct bolt up for the old pump...
EDIT: You do know you can disconnect your current oil injection set-up(VRO) and use your existing pump as a fuel pump only.... Easy to do if your current pump works good now...
http://www.maxrules.com/fixomcvro.html ] Click Here for replacement pump [/url]
