A little confused, I have a 92 Johnson 60hp, that I used everyday until 2 months ago. It was running great a couple of months ago. Today, I pull it out to start and clean it up. It would stumble and die. So I drained the carbs, same thing. Pulled carbs, just to check, #1 carb jet was plugged a little. Cleaned and put back on, now same condition. It did run for a little bit, but when you try to advance the throttle and it dies. It also want even fire if the throttle and timing is advanced further then idle. Tried separate fuel tank, both fuel is good, no water and fuel had stabilizer in it. Any ideas???? Thanks for your help guys.
