92 Lund Pro V anger DLX leaking
sucena
My 92 Lund started to have a leak this year. It didn't have much of a leak in the past, but this year it's more noticeable. I have to use the bilge a few times if I'm on the water for a full day. I haven't crashed or anything like it so it's puzzling.
Does anyone know if this Lund model is prone to leaking and where?
I looked underneath and can't find anything out of the ordinary. How does one find a leak on a boat that has a subfloor?
Any suggestions would be appreciated.
Thanks
bonz_d
Re: 92 Lund Pro V anger DLX leaking
With the subfloor/decking it's going to make it hard. Could be anything from a livewell fitting, transducer mount to a leaky rivet. Though I find it hard to believe it would be a rivet. The only way I can think of to find it would be to trailer it then fill it with water to the waterline and see if you can locate a wet spot.
Good luck, hope you can find it.
thiker15
ck the livewell pickup screen, thats were mine was leaking
cooterdude
look at the transom bolts that have no sealant on the back of the boat that is where mine is leaking
