92 mariner 90 hp stator
Sportsman558
My stator reads 120 and was told it should be between 200-300. How long will it last? Should I get a new stator or just run it? Also should I go with factory or aftermarket? Thanks for the help.:D
sschefer
Re: 92 mariner 90 hp stator
Does it cause you any problems.. poor idle, hesitation, low WOT RPM... If not, you readings are wrong and your stator is fine. Run it... Don't create problems where they don't exist.
Sportsman558
I do not know on a dva my mechanic told me it was at 120 and should be at 200-300. Should I continue to use until it dies or replace now?
