My engine trim has always bled down really slowly requiring me to trim up a little every few minutes or so. This year all of a sudden it can't drive the boat without the motor getting forced down. Sitting still it can lift and lower fine but under a load it gets driven down.<br /><br />The unit is a single cylinder with a motor/pump next to it. What would cause this? I opened it up and found gears, check balls, etc. Is this easy to fix? Are rebuild kits typically available? <br /><br />The motor and pump and cylinder seem fine. I am guessing its a leaky check valve somewhere.<br /><br />Thanks in advance.
