I have a problem I hope someone can help with. I should first say that I am not very versed on working on any outboard motor issues...but I am going to try!
I have a 1992 Merc 135 that the tilt/trim motor has been leaking fluid. It is now out of fluid, the motor still runs when I hit the switch, but nothing happens. This all came about too quickly for me to get it serviced before the engine was "locked" in the down position.
My first problem is that the motor is in the down position and I can't lift it. Someone locally told me there is a large screw on the side of the engine that would release it from the tilt trim and I could then get to the tilt/trim to replace the seals.
Does this sound correct? If so, would anyone be willing to share the details of how to do this to a novice (me)?
Thank you in advance for any guidance you can provide!
Thanks,
Jim
Thanks,
Jim
