Just thought I'd give you all an update on the charging problem I've been having with my '92 Merc. (I thought it was a '91 but I did some checking and found that it's actually a '92) After all of the overcharging issues and non-functioning replacement regulators I went ahead and replaced the entire charging system with an OEM red stator kit and new OEM regulator. It cost about $400 which is more than the aftermarket CDI components but the bad experience I had with the CDI stuff makes it well worth the extra cost.
I went out yesterday afternoon and picked up the new parts and got home and installed them. It wasn't that tough and I spent a little extra time inspecting and cleaning all of the ground connections because some of them looked a little suspect. After finishing the installation and rechecking everything I put the muffs on and fired her up. I'm happy to report that it appears to be functioning properly. I ran it for over twenty minutes and varied the RPM's and it's putting out between 14.2 and 14.4V so I think I've finally got the problem solved. I've got to work Saturday morning but as long as the weather cooperates, I'm planning on a good shakedown cruise early Sunday morning.
Thanks again for all the responses I had on my previous posts concerning this problem. Your input is greatly appreciated.
See ya on the water!
John
John
