Hello all,
well
When I purchased the boat it had spark in both motors and would fire. Took it home a set to work getting the power tilt and trim and trim tabs fuctioning with a bit of help from the forums. I also cleaned a few connections, checked fluids and impeller. went to start the motor a few nights ago and it would not fire. Its a
92 4.3l/ 6T2 mercruiser Yamaha outdrive. On 26ft renken
I went to check the spark and it was absent. Followed plug wire back to what I thought would be a distributor but found insteadwhat I can only describe as two coil packs, 1 with four plug wire and 1 with two. In the place of the standard distributor cap with the male ends is a sensor with four wires: grn, red, white, White/black that feed directly into the ECU/ignitor box ( 5"X8"x1.5" black box with info sticker on it labeling oil type, spark gap etc) basically I'm at a loss I would like to trouble shoot but I'm not even sure the correct name of the parts and I can't seem to find a ignition module .
so where would the ignition module be it it has one?What type of ignition system is this? And any info would be greatly appreciated.
well
