tarheelebbtide
- Joined
- Jul 4, 2008
- 94
I have a 1992 350 Mag Mercruiser with Alpha 1 drive unit. I had the engine rebuilt last year and somehow the mechanic "lost" my Alpha 1 unit. He replaced it with a newly rebuilt unit that is a 96 model Alpha 1. The unit seems to be working fine with one exception...I cannot run the boat trailered because all of the water from the flush muffs simply streams out the hub of the prop. I'm doing the exact same things I did with the old unit in place, but all of the water comes out of the prop hub and none through the bellows.
It might also be worth noting that my boat was modified to put the exhaust thru hull above the waterline before I purchased it. I don't know if that makes a difference or not.
I have placed a large tub down and trimmed the drive down into it and it picks up water fine using this procedure and water flows from the bellows. It also does fine in the water. Should I be concerned here?
