PrplGld
- Joined
- May 7, 2005
- 123
'92 Nissan NS90A (SN 3B7-1-15212)
Experiencing the limited revs problem once again. My motor wouldn't go over 2500 rpm. I think I'm finally down to a water pressure sensor problem. I took off the water pressure switch assembly and looked at the switch on the back. There's a light blue wire cut with copper exposed. The parts catalog only shows the ground and one other wire (the one currently connected is red, as can be seen in the first pic). Seem the parts catalog indicates that a light blue wire should be coming from the switch.
Should the switch maybe be replaced or adjusted? Is it wired incorrectly?. I'm not sure how to adjust it though. My mechanic can't get to it for 3 weeks. I checked the thermostat, there's no trash caught in it.
I'm wondering if the adjustment screw is set too low (bottom pic, without the black switch box).
