Stumpknocker
- Joined
- Dec 11, 2003
- 774
92 Evinrude 70 on a Sea Nymph 17ft bass boat. Runs great.. cranks reliably...yet when fishing Sunday after several moves around the lake...it won't crank. <br /><br />Ran the primary battery down.... switched fuel tanks and batteries.... eventually (45 min) it cranks after letting it sit. Then we discover the shift lever is no longer working. Had to shift manually to get it in gear. Found that a plastic bushing on the gear cable had failed. It no longer held the cable firm and instead of engaging the forward or reverse.. it just slips the entire cable housing back and forth. <br /><br />Now we find that the thing will crank in Neutral or Drive or Reverse. Bombardier advises this is not normal and should have the ignition locked out unless in Neutral. <br /><br />Does anybody think that the failure to start along with the shift lever failure are just a coincidence? Motor cranks fine now in or out of gear. I don't think there are any problems in the carbs... runs great...other than this one time. Is there a connection between the failure of the shift linkage and the engine turning over and not firing? No way to test for fire on the water but have to assume there was fire. Possible bad ignition switch? Any thoughts or experience here?<br /><br />Thanks...
