92 v150 lower bearing retainer
issachar
I need to know if anyone has the torque specs for the bearing retainer ring on my lower unit. Seloc for some reason omits this info totally. I need to replace the two seals on the prop shaft. Any other need to know tips would be helpful, seeing how I am flying blind somewhat.
Laddies
Banned
Re: 92 v150 lower bearing retainer
Lube it with 2-4-C grease and torque it to 210 ft lbs.
Chris1956
Laddies, Do you really mean 210 ft lbs? I for one are not strong enought to make it that tight, and I wouldnot think the threads would take that, being aluminum
Laddies
Banned
Chris, this is out of my Mercury V/6 manual date 3 of 92.
Chris1956
Laddies, Thanks for the info. All I can say is
Holy Cow! That's a lot of torque!
j_martin
To put it into perspective, 80 ft/lbs on a 1/2 inch bolt is 3640 lbs at the thread. 210 ft/lbs on a 4 inch nut is 1260 lbs at the thread.
hope it helps.
