My XP 200 is on a 19 foot Astro F/S. At different points in the RPM range this thing pulls to right.<br />I have adjusted the tab on the lower unit as far as it will go and it has helped the problem by 50% but the more I am into the gas the harder it pulls. What is funny about this problem is that cruising at about 35mph it drives straight, get into the gas and pulls right. Steady the speed at around 45-50 it pulls right slightly but tolerable. The more your in it the harder the pull. I have dropped the motor and it did not help the pulling problem but I did drop nearly 300rpm (I am going to raise the motor back up).<br />Any other suggestions?
