JPatterson350
- Joined
- May 16, 2010
- 10
Im looking for help and getting discouraged quick. I just bought a 93 Maxum with the above motor 120HP Force.
First few times out tilt worked but would fall under load while trying to trim up - dock and idle no problem (3 ram system)
Now the boat motor won't tilt without help / someone pressing the trim switch and lifting the motor. When you trim down while holding the motor there is literally no pressure. This is an Eaton Pump/motor
I took the boat into a local shop and the guy said I need a pump kit part #811702, guess what it's obsolete. 100 bucks later I sill have a system that doesn't tilt. He said the motor was fine. I asked him if he thought I should replace the manifold kit #823085 and he said NO. I just wish I could pull off the eaton motor and send it out for a rebuild but all the hydrolic shops aren't interested.
I called another shop and they said to buy a entire new pump/motor kit part #853515A1 - that's over 900 bucks. I'm starting to think this is a lost cause so any help would be greatly appreciated.
J
J
