I need to replace the attached plug before my new stator/regulator from CDI goes in. The way I see it is this is part # 513664. Am I correct? Also, I need to remove the two contacts from the existing cooked connector. I have tried this before on my trim motor connector. It is a royal PITA. There has got to be a trick to it. I tried every single small blade screwdriver and a modified hacksaw blade. Never did get it done on the trim motor. I cut the wires and spliced and heatshrunk. I don't want to do this on this connector. Any ideas? Also, where might I obtain a replacement?
Thanks
Sid
Thanks
Sid
