93 200 vindicator and 92 175 intruder part compatability
bigbassbrent
Hi- I have a 92 175 intruder (e175glenc) and know of a 93 200 vindicator that is available for parts. Does anyone know how compatable these 2 engines are??? Can my engine accept parts from a 93 200 vindicator or are they very different engines? For instance can I use the starter on either motor?
maxum1800
Re: 93 200 vindicator and 92 175 intruder part compatability
Hey , I just found this forum,registered and am unable to post a question as I can't seem to figure out what to click on to post a question. I'm sorry but I don't have an answer for your question but I thought you might want to help me as you most likely are still on the forum. Thanks in advance if you can help Tom
dajohnson53
I don't know the answer, but I think the most definitive way would be to use the the www.brp.com website. It has parts finder for all the johnson and evinrued outboards. You can pretty easily compare part numbers for the two engines if you have the model number for both. THere is even a "pick list" feature where you can select a part and put it on that list, which you can then print. For instance, you could "pick" the part from the e175glenc and the same part for the other and then compare.
To maxum1800: look for the button that says "creat new post" at the top of the main forum page.
Dhadley
Depends on what parts you want to interchange. The lower units can be made to swap, they use the same props. Same gas & oil but not much after that. The 92 is a 60* looper, the 93 is a 90* looper.
