Re: '93 225 tilt/trim flush and bleed instructions
It was making a sound like it was low on fluid last year. This weekend, I removed the reservoir cap when the motor was tilted up and fluid ran out. I captured the fluid and it was very dark - Not sure if that means anything. <br /><br />Since fluid ran out when I removed the reservoir cap, I don't know if it was overfilled or not. I don't know how much, if any fluid I will be able to add. The reservoir cap looks like it is in the bottom third of the reservoir. The reservoir has lines on it, but there is no way I could fill to that level. <br /><br />Thank you for your reply!
