93' 25Mercury OD278205
rlindsay
I need a part number for the fuel connector on this engine and some advice on how to order it. The merc site seems not to be working. Parts cannot be located without a dealer and that's fouled up. The plastic inlet cracked and leaks. Thanks for any help. Rick Lindsay
WillyBWright
Re: 93' 25Mercury OD278205
Welcome to iboats and wander on over here... Merc Connectors :) <br /><br />But I'll bet what you need is attached to the motor. That's 22-15781A9 and only available from a Merc dealer. Check your yellow pages.
rlindsay
Willy, Thanks much for that part number. One bolt holds it onto the cowling base. Since it may take some time to receive it , I was wondering why I couldn't make a direct connection. Could I cut the connector off my fuel hose and go straight in for a short term fix? The fish are biting and I'm desperate. Thank's again, Rick
tashasdaddy
inho, it could be a permanent fix. my only concern is the rubbing and wearing, going into the cowling.
rlindsay
Dear 8 Below and all you husky lovers, I think the problem is fixed, The part should be here tomorrow, 40 bucks worth. Next day is expensive. If this happens again especially on the water now I have a plan. This is the greatest forum I've ever seen. I have had nothing but success with every question. The knowledge base here is just incredible. Rick Lindsay
