'93 75-90hp mariner/merc before I tear it down
cdnfthree
Hello, After sinking my boat up to the cowling in salt water during a wind storm rust took over. Recently the bottom 1/4" of the "swivel pin steering arm"(hollow tube that shifter travels through) chiped out from rust and the retaining ring has no place to grab hold of. This is all below the bottom yoke,the yoke is already in place, and all of the parts are bolted on, so does the retaining ring play a functional role (the O rings and bushings appear by diagram to be trapped exactly where I need them to be). Does anyone know of what I am refering to? Is that retaining ring an integral part once initial installation has taken place or not? I'd be grateful for any help. Carter
cdnfthree
Re: '93 75-90hp mariner/merc before I tear it down
The ring looks like might just hold things together while you bolt the yoke to mid section. Am I right?
Chris1956
The retaining ring is not too important. They fall off all the time. As long as the bottom yoke is functional and the lower mounts are good, the motor should be fine.
cdnfthree
Thanks alot! I'll replace the rusted shaft when I have to or when I'm doing more than just that. Pulling the powerhead not 2 hard but I'd rather not. It should hold for a few more years. I'll keep an eye on it. Thanks again
